Clutch Problem 2 *****
Old Sep 25, 2006 | 04:07 PM
AcuraIntegra305's Avatar
AcuraIntegra305
Default Clutch Problem 2 *****
My clutch has only about 4-6 inches maybe less or a lil more give or take between it being pushed down all the way and released all the way. if i have the clutch pressed completely down if i release the clutch less then a inch it already starts to idle low and almost stall. my MC and SC are only like 1yr old. so was wondering why its like that maybe, i had my brakes done like 4 days ago and after that it seemed different so maybe that had something to do with it.
Old Sep 25, 2006 | 04:37 PM
Brar's Avatar
Brar
adjust your clutch cable?
Old Sep 25, 2006 | 04:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Hydraulic systems don't have a clutch cable.
I would look at the pedal adjustment at the master cylinder and see if it is can be adjusted to engage farther from the floor. Also check the fluids and bleed the clutch. Maybe there is air in the lines. If that doesn't help, your clutch may be worn out and in need of replacing.
Old Sep 25, 2006 | 07:18 PM
AcuraIntegra305
ty so much das schmoooo u always are alot of help
Old Sep 25, 2006 | 09:08 PM
Provocateur
On permanent hiatus
I try.
Keep us updated on what the problem is.
Old Sep 26, 2006 | 08:47 AM
flybye's Avatar
flybye
Mine did that and it was the master cyl. also check the fluids, you never know you might me low
