clutch problem*****
Old Sep 24, 2006 | 04:30 PM
JDM_199's Avatar
JDM_199
Default clutch problem*****
well my clutch bites really low. i will have my clutch pushed down all the way to the floor and when i release it just a little bit, i can already feel the clutch biting. and theres no grinds while going through the gears, but 3rd only grinds while taking it up high rpms. but if i shift low rpms, it doesnt grind. can anyone help me with this problem? i have a sg2 act clutch. i pressure bled the clutch lines too.
thanks.
Old Sep 24, 2006 | 04:33 PM
Snoopy's Avatar
Snoopy
been there done that
you can adjust the clutch engagment point. and that grind sounds like a bad syncro. i have the same problem with my tranny. :hs:
Old Sep 24, 2006 | 05:07 PM
JDM_199's Avatar
JDM_199
where is the clutch engagment point located? and how do you adjust it?
Old Sep 24, 2006 | 05:49 PM
DaGip's Avatar
DaGip
4N2Ner
yup your going to need to cash up for some syncros. my also have worn out. 3rd grinds only at high rpms above 4k.
Old Sep 24, 2006 | 05:57 PM
Hondaman's Avatar
Hondaman
Black Pearl
After you bleed it, is it better for a while then gets worse again?
If so, you may need a new master or slave cylinder.
Old Sep 24, 2006 | 06:05 PM
JDM_199's Avatar
JDM_199
ive bleed it like 2 weeks ago, and since then, its been the same. how much would it cost for new syncros? and what would an average shop charge to put them in? and where can i find them?
and is there any way to adjusting my clutch? like by the clutch pedal or anything.
Old Sep 24, 2006 | 06:29 PM
DaGip's Avatar
DaGip
4N2Ner
i got mines from (gearspeedinc. com) got the whole set for $250. my uncle was too busy with his paying costumers lol.no free install for me. so i had to go to my mechanic. he charged me $80 per syncro. so my guess would be for install $80-100 per syncro.
Old Sep 24, 2006 | 07:06 PM
JDM_199's Avatar
JDM_199
wow, thats expensive. almost better off buying a new(used) trans.
Old Sep 24, 2006 | 07:11 PM
DaGip's Avatar
DaGip
4N2Ner
what ever fits your budget. you might have the same problem again a year or two later. so just secure the tranny you have now man. a lot cheaper.
Old Sep 24, 2006 | 07:21 PM
JDM_199's Avatar
JDM_199
i didnt even think of it that way. yeah, better off just fixing mine now and have it last longer. well thanks for the info, help me alot.
