whistle sound
Mine used to do this during cold conditions. I replaced the intake manifold gasket, torqued to spec in the correct pattern. Problem solved!
Also to the thread starter: When was the last time you replaced your air filter? Check that a vac line didn't work its way loose. Or the intake pipe on the T-Body.
I hope between all the suggestions you figure something out. A video or sound recording would certinly help in diagnosis. Good luck!
h:
