89 Integra LS - Idle Adjustment
I have been passing, but only by a hair. I want some distance from the cutoff point. It is only low speed HCs that is a problem. High speed - no problem. If my idle were higher, then it would solve the emission test problem. I wish that I knew how to solve the problem otherwise.
I am not sure what the timing is set at - but if it were not set right, wouldn't the high rpm produce high HC as well?
Here are the latest numbers:
RPM @2613
HC = 81 (200 is limit)
CO = .35 (1.2 is limit)
CO2 = 14
O2 = .62
RPM @910
HC + 192 (200 is limit)
CO =.18 (1.2 is limit)
CO2 = 14
O2 = .72
Two years ago, right after an engine rebuild, I got the following:
RPM @2444
HC = 79 (200 is limit)
CO = .55 (1.2 is limit)
CO2 = 14.2
RPM @1005
HC + 100 (200 is limit)
CO =.17 (1.2 is limit)
CO2 = 14.9
I was expecting after a rebuilt motor to have excellent results. But the high HC at low rpm was a surprise. Before rebuild I had similar numbers. If rpm here is lower (e.g. 925), then the number is much worse.
RPM @2613
CO2 = 14
O2 = .62
RPM @910
CO2 = 14
O2 = .72
RPM @2444
CO2 = 14.2
RPM @1005
CO2 = 14.9
