Bye Bye ABS Unit
Old Aug 19, 2006 | 04:11 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
Default Bye Bye ABS Unit
So me and Teg92 are finally doing my abs removal this morning. Hopefully it should take us 2-3 hours. Wish us luck! :chuckles:
Old Aug 19, 2006 | 11:27 AM
DaGip's Avatar
DaGip
4N2Ner
why the need for removing it, what are you planning to do afterwards?
Old Aug 19, 2006 | 12:07 PM
sherwood's Avatar
sherwood
I missed Sean
sometimes they want to lose more weight or sometimes it's because they want to control the brakes and lose the ABS system for control purposes.
Old Aug 19, 2006 | 01:34 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Stage 46 weight reduction y0!@! Hope all goes well dude.
P.S. when are you going to let me know the situation with the axles.
Old Aug 19, 2006 | 02:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
JDM Ricer. :db:
Old Aug 19, 2006 | 02:09 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
So are u Using OEM non abs brake lines or are u gonna to bend ur own?
Old Aug 19, 2006 | 06:02 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
so heres how it went down, me and teg92 got everything out and connected in about 3 hours everything went pretty smooth till we realized we put to gaskets between the mastercylinder and booster. all in all went pretty good though. still need to bleed the lines.
i used a RS Booster, RS Master Cylinder, Oem RS brake lines, Oem RS Proportioning valve, everything is brand new too thanks teg92 for the help and carta79 for bringing over the bud lights :chuckles:
Old Aug 19, 2006 | 06:06 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
sorry for the double post but heres the reasoning behind pulling out the abs.
1. the previous owner installed axles made for a non abs b series car so it didn't have the abs nut on it making the abs light go on.
2. when i installed my omni rear lower control arms there was no bolt spot for the abs lines so i was forced to zip tie them and later on i decided to just cut them out.
3. yes im a weight whore and NA for life kindda person. The 28lbs and clean engine bay was the main reason, im not gonna lie about that :chuckles:
Old Aug 19, 2006 | 07:43 PM
Provocateur
On permanent hiatus
28 lbs? Damn, I didn't realize it was so heavy. That weighs as much as an A/C system.
Old Aug 20, 2006 | 05:08 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah with everything removed including the abs unit, abs control unit, lines and sensors 28lbs.
