GS-R Exhaust Rattle!
Old Aug 16, 2006 | 10:19 PM
05CivSe's Avatar
05CivSe
Rick
Default GS-R Exhaust Rattle!
I have a 99 that as soon as it heats up the exhaust rattles. I have a Greddy Evo II full cat-back but it doesnt seam like it is coming from that.
At about 2600 rpm I get a constant rattle, I thought it would be the cat heat shield so I removed that, nothing changed
Someone told me that on the back of the header there is a bolt that can rust or come loose and start to rattle. Ever heard of this?
Someone also said it could be a defective muffler and that the baffles are loose.
Just wondering if anyone has ever had this problem, and what the fix was. It is anoying the crap out of me!!!!
Old Aug 17, 2006 | 02:25 AM
R_Squared's Avatar
R_Squared
LEVEL UP
I have a similar problem...my exhaust makes kind of a rattle that squeaks sometimes. I think it's because the gasket between the manifold piping and the cat is wearing away. Annoying as hell...
Old Aug 17, 2006 | 02:55 AM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well when i first got my car it did the same thing at 3000 rpms turned out to be heat shield that had cracked and started to rattle
Old Aug 17, 2006 | 06:05 AM
05CivSe's Avatar
05CivSe
Rick
I removed the heat shield, so thats not it..... my orig exhaust doesnt llook the best though, I am going to take it to honda today and see what they say
Old Aug 17, 2006 | 07:25 AM
Topend's Avatar
Topend
scooted
why not lift the car up (in a real bay that is) and hit the exhaust with the bottom of your fist till you hear it. thats what i did to my former S13 after I already had lots of bolts off. Pissed me off it was so simple.
Old Aug 17, 2006 | 11:17 AM
Snoopy's Avatar
Snoopy
been there done that
do you still have the stock header? if it's coming from the cat area and you took off the heatshields, most likely you have the dreaded b-pipe rattle common on gsr's. replace the header and it's gone.
Old Aug 17, 2006 | 11:29 AM
BtTurboM3's Avatar
BtTurboM3
my freind has the exact same problem at 2.6k rpms. he has a conversion and we are sure that from the conversion that the cat is ratteling. but see what honda says.
Old Aug 17, 2006 | 12:10 PM
05CivSe's Avatar
05CivSe
Rick
Honda couldnt duplicate it!! I hate when cars do something constantly until you take them in and they are completely fine.
Oh well back to sweating may ass of clay barring..... Any other suggestions let me know, I will check the header, and cat
Old Aug 18, 2006 | 01:27 AM
Kai's Avatar
Kai
Rotorphile.
Do you have a short shifter? Those can rattle against the exhaust since they stick out lower then the stock shifter.
Old Aug 18, 2006 | 12:30 PM
05CivSe's Avatar
05CivSe
Rick
Ding Ding Ding!!!!! That was it! I took it to a local muffler shop today that has done awesome work for me in the past, and after burning half of my clutch up putting pressure on the engine they figured out that was it. They welded the inside pipe to the outside pipe (its a ghetto fix but it works)....... Its only temporary anyway b/c the turbo is coming soon!!
