broken screw on valve cover?
Old Aug 12, 2006 | 03:48 PM
gta4life's Avatar
gta4life
Default broken screw on valve cover?
ok well basically i let my buddy take a look under the hood of my '90 teg ls non-vtec to try and see if he could find out where i was leaking oil, well he thought it was coming from the valve cover seal so he tried tightening one of the screws that bolts in the valve cover but he broke the head of the bolt right off so now it looks like its stuck in there good..so i was wondering if this is a big deal at all and if i have to change iot how shoudl i go about getting it outt??? , alright thanks everyonee
Old Aug 12, 2006 | 04:01 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You have to take the whole cover off and undo the shaft. It is threaded on both sides and you can grasp it in the ctr. w/a wrench and turn it out of there. The dealer should have those on hand and they are about 3 bucks a piece.
Old Aug 13, 2006 | 08:34 AM
fastback's Avatar
fastback
Make sure you never let that guy touch your car again...
Old Aug 13, 2006 | 01:37 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
They are not that strong. A 1 armed ethiopian could snap it off.
Old Aug 14, 2006 | 09:39 AM
fastback's Avatar
fastback
Which means someone who doesn't know that shouldn't be tourquing them down like the Hulk.
Old Aug 14, 2006 | 12:54 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Exactly...
Old Aug 15, 2006 | 08:47 AM
fjm1's Avatar
fjm1
G35
Kinda funny. If it leaks tighten it......
Old Aug 18, 2006 | 01:49 AM
Kai's Avatar
Kai
Rotorphile.
Spec on valve cover nuts is 8lb-ft. That is 'snug,' not 'tight.'
Old Aug 25, 2006 | 09:57 PM
jrw1818's Avatar
jrw1818
yea i figured that out the hard way... i changed my gsr valve cover from black, to red.. red is a type-r color.. but i'm goin with gray an red for my car colors.. an i tighted the nuts too tight. so when i went to loosin the nuts they where just spinning on the bolt... so i had to cut them off an buy two new ones... an buy new rubber an metal washers.. it ended up costing 50.00... for the parts..
pinealean
Accord
2
Jun 8, 2005 12:23 PM
THC
Engine Swaps, Tech & Tuning
5
May 6, 2005 06:46 PM
excitid
CRX & Pre 92 Civic
5
Jan 8, 2003 03:33 AM
gsr44
4
Jun 20, 2002 06:32 PM
