b20/vtec
Old Aug 1, 2006 | 01:48 PM
cuccas ass's Avatar
cuccas ass
Default b20/vtec
i have a 92 teg gsr and just bought a b20 motor i want to make a ls/vtec but i was wonder how good the stock b20 block will hold up and for how long and if any one knows what kind of power it would make let me know
Old Aug 1, 2006 | 01:51 PM
Snoopy's Avatar
Snoopy
been there done that
it will last as long as you want it to last provided it's built correctly and you dont drive like a jackass everywhere you go. power numbers can be anywhere from 180-250whp on a serious NA setup or higher with boost. all depending on what you wanna do with it.
Old Aug 1, 2006 | 02:04 PM
cuccas ass's Avatar
cuccas ass
well it is a stock b20 block and one of my friends told me that his friend did the same thing and w/ in 2 week(normal driving a few races) he threw a rod or somehting i just dont wanna speend all this money then have the shit brake in a week or and me be out all that money
and it is all being put together by a cefitfied technition
Last edited by TheOtherDave™; Aug 1, 2006 at 04:18 PM. Reason: This isn't AIM. Collect your thoughts and post once, editing when necessary. Thank you.
Old Aug 1, 2006 | 03:36 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
b20vtecs are a lot of fun.. i had mine for about 15k miles daily driven with only a block guard and a stock gsr head with a whole bunch of boltons.. took it to 8k redline plenty of times.. it held together real well until i checked the compression and it was low in 3 cylinders.. i decided against rebuilding it and went back to a gsr block..
Old Aug 2, 2006 | 10:09 AM
Snoopy's Avatar
Snoopy
he probably didnt have it tuned, didnt have it built correctly, and revved the piss out of it. this is how lsvtecs and b20vtecs get bad reps. by dumbasses that dont know what they're doing.
Old Aug 2, 2006 | 02:24 PM
sherwood's Avatar
sherwood
I missed Sean
the problem was most likely the fact that he still had the stock rotating assembly in. the rod bolts arent made to rev to 8k+
Old Aug 2, 2006 | 02:55 PM
jDm.cAr.bOy's Avatar
jDm.cAr.bOy
pSc
well im planing to go b20 vtec to does anyone know what i have to do to my head will a b16 head work
Old Aug 2, 2006 | 04:04 PM
Snoopy's Avatar
Snoopy
here, i even did the search for you
Old Aug 3, 2006 | 06:09 PM
ALLMOTOR18's Avatar
ALLMOTOR18
Yeah, thats right.. the Stock rod bolts are no good.. Just get some ARP Rod bolts and you should be OK.. Balancing the rotating assembly is good, but isn't absolutely necessary.. If you plan on revving past 8K i would do both..
If built right, the B20/Vtec can be as reliable as any OEM motor... I would recommend some RS Machine Cast Pistons in 84.5mm... Alot of people are making 220+ whp with them..
Old Aug 3, 2006 | 06:53 PM
gingas's Avatar
gingas
If you go B20 Vtec would you want to sell your gsr tranny. Good luck with the build
