Throttle Cable?
Old Sep 25, 2002 | 09:55 AM
Int3gra'd's Avatar
Int3gra'd
Default Throttle Cable?
has anyone had any luck tightning their throttle cable?
i noticed mine was a lil loose, but second guessed myself as to whether or not I should tighten it up.
advice would be much appreciated.
Old Sep 25, 2002 | 10:46 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Man I remember back in the day when me and newgsrdriver adjusted his throttle cable. Me, him and his boy Max all standin over the popped hood (this is in the pre-JRSC days) looking at the Helms trying to guess what the hell "preload" means. Man them's was the good ole days...
Anyway, go ahead and mess with it, just be sure you bust out a ruler and don't change anything too much.
Old Sep 25, 2002 | 12:35 PM
newgsrdriver's Avatar
newgsrdriver
Haha I remember that
Damn Helms manual is confusing sometimes with all these wierd words...why not just:
"Step 1 - loosen bolt"
"Step 2 - adjust"
That would work just fine!!
Old Sep 25, 2002 | 01:04 PM
JEFFOS69's Avatar
JEFFOS69
Yeah it comes with a bit of slack and you can tighten it up just be careful not to actually pull the throttle and keep it that way while tighening. I suggest you do it with the car idling so you can hear if you tighten it too much.
You gain some pedal response by tightening the slack up.
Old Sep 25, 2002 | 01:32 PM
Snoopy's Avatar
Snoopy
been there done that
look here
i know its for an si in the pics but it should be basically the same for tegs.
Old Sep 26, 2002 | 08:34 AM
Int3gra'd's Avatar
Int3gra'd
thanks for your help.
Old Sep 26, 2002 | 08:53 AM
antarius's Avatar
antarius
Large Member
Yeah.
I noticed a slight difference.
I had to readjust to my clutch/gas positioning when shifting though, I always found myself slipping the clutch cause I was giving it too much gas.
Old Sep 26, 2002 | 09:11 AM
dubcac's Avatar
dubcac
I
It's easy, I noticed better throttle response.
Old Sep 26, 2002 | 09:27 AM
IntegraFreak's Avatar
IntegraFreak
Keep in mind that you will have to keep readjusting it constantly, the cable's tension goes back to its usual after a couple of months.. I used to do it until I had done it so many times that the bolt edges starting wearing out, and that's when I decided to stop playing with it and leave it.
Won't get you more speed, and if you have automatic, it'll make your shifting jerk more.
estoner102
92+ Civic/EL & Del Sol
Apr 3, 2004 06:39 PM
LateApex
Oct 22, 2003 01:43 PM
jermothedrunk
2
Jul 24, 2002 10:58 AM
madeiniraq
Engine Swaps, Tech & Tuning
Jul 14, 2002 07:49 PM
likaciv
6
Jul 6, 2002 09:17 AM
