engine ticking... :(
Old Jun 24, 2006 | 07:47 PM
Robstunner's Avatar
Robstunner
y0! Vito!
i just changed the oil. 5w30 and a fram filter. i dont think the filter will have anything to do with the noise. i had to change the oil anyway so good timing i guess. i think its the alt or injectors. i guess it gives me a good reason to get ITR injectors
Old Jun 24, 2006 | 08:33 PM
dubcac's Avatar
dubcac
I
Normal.
Old Jun 24, 2006 | 09:01 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Why would you get ITR injectors? They are identical to what you have now.
Old Jun 25, 2006 | 07:46 AM
Robstunner's Avatar
Robstunner
y0! Vito!
i know i was kidding.
i dont think its normal, you shouldint hear ticking at 3krpms on constant speed.
Old Jun 25, 2006 | 10:00 AM
carta79's Avatar
carta79
Life after death
I'm assuming that the valves were recently adjusted. What's the oil level at I wonder?
Old Jun 25, 2006 | 11:40 AM
boehmdw97's Avatar
boehmdw97
my gsr made a similar noise when I was running 5-30 in my car. I had my valves adjusted, got some injector cleaner, and changed my oil to 10-30 and the noise almost totally went away. When the honda engines get a little older with more miles, it's a good idea to change to 10-30 b/c 5-30 just doesn't give you enough protection. It also depends on your location. Different altitudes and outside temperature ranges during the day make a big difference too. You are running n/a right?
Old Jun 25, 2006 | 11:41 AM
boehmdw97's Avatar
boehmdw97
royal purple oil rules by the way.
Old Jun 25, 2006 | 01:00 PM
Robstunner's Avatar
Robstunner
y0! Vito!
yeah NA. injector cleaner?
when i turn the car on it sounds like a desiel, the injectors, but when i tap the gas the injectors stop making noise.
valves got adjusted no longer than 1 year ago.
changed the oil yesterday, no as a precaution, just that it was time to change it, sound is still there. the noise i hear in the car while driving, the ticking, im almost 90% sure its the alternator. when i spray that silicione the ticking in the car while driving almost goes away.
Old Jun 25, 2006 | 02:05 PM
dubcac's Avatar
dubcac
I
It's normal. Even when the valves are perfectly adjusted, you'll be able to hear them. Your injectors will also tick like a valve tap sound.
Old Jun 25, 2006 | 02:59 PM
christheape's Avatar
christheape
I adjust my valves every 3 or4 mounths or when I start hering that noise. I would also switch oil (Royal Purple).
