G3 Antenna
Old May 31, 2006 | 07:05 AM
gsr2k's Avatar
gsr2k
Default G3 Antenna
My antenna wont go down - the motor is cranking, but the mast doesn't move. I'm betting it's the plastic thing is broken inside.
Three questions:
1. Can I temporarally disable the motor before I get the antenna fixed?
2. Any ideas where I can find a new antenna?
3. What kind of labor is involved with replacing this?
Thanks
Old May 31, 2006 | 08:10 AM
Buyimports2's Avatar
Buyimports2
go to lo-customs.com (i think that's it) and buy the shark II antenna. It looks like a s2k antenna and only costs like 30$. It works like a charm and isn't that bad to install. You just need some electrical tape and a little mcguiver action to plug in the booster. If you have any more questions feel free to pm me. I've had it in my g3 teg for over a year and the only problem i had was when a drunked kid decided to take a tree limp and baseball-bat it. It still worked after that too.
Old May 31, 2006 | 08:38 AM
gsr2k's Avatar
gsr2k
That website didn't load and Google didn't turn up anything for it.
Do you have a picture of the antenna installed?
Old May 31, 2006 | 11:25 AM
Buyimports2
Crap, I don't know what is wrong with the website. Like half of it loads but it looks like it's down. Anyways, here is an article. http://www.team-integra.net/sections...?ArticleID=815
The person who wrote the article bought the wrong antenna which is why they had to modify a brace for it. My antenna was like 10x easier to install. The one in the artcle looks almost identical to mine.
I don't have any good pics, but here it is anyway. I love it.
Old May 31, 2006 | 01:03 PM
96BLKGSR's Avatar
96BLKGSR
You can disable the motor by unpluging it from behind the actual motor (it is a harness with two wires, I believe), just don't unplug the actual atenna lead (thick black wire) or you will lose reception.
Old Jun 1, 2006 | 08:30 PM
Kapa6ac's Avatar
Kapa6ac
I order antenna mast from http://www.antennamastsrus.com/
If you dont need to remove the motor it's 10 mins job.
Removing a motor is not a big deal either but you will need
to disconnect the rear plastic panel. You dont need to remove the
back sit as in DIY article ...
cheers
Old Aug 4, 2006 | 11:52 AM
gsr2k's Avatar
gsr2k
cheers
I just ordered my antenna mast...I'll let you know how it goes.
