Odd Engine Hesitation...
Old Sep 23, 2002 | 09:37 AM
ChillOutWayne's Avatar
ChillOutWayne
Default Odd Engine Hesitation...
i have a 94 gsr with catback, header and testpipe...anyway after the engine has cooled completely, after restarting and traveling down my block accelerating slowly, i get an odd hesitation at around 2500 or 3000 rpms while accelerating...if i hit the gas pedal a little harder it will move on and accelerate normally and after that initial 'hiccup' it runs fine..as to describe the hesitation: it seems as tho the car is backfiring rapidly and my bro says that it sounds like a rev limiter as i go down the block...i really dunno where to start, i get a check engine light occasionally but not all the time...any opinions or help would be greatly appreciated...thanx in advance
Old Sep 23, 2002 | 09:50 AM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
when's the last time you had a tune up....and i suggest you get one done if you haven't had one in a while
Old Sep 24, 2002 | 07:09 PM
ChillOutWayne
i actually stay on top of my car pretty well...ive done everything recently other than spark plug wires...including spark plugs, cap, rotor, oil, valve adjust., all fluids and all....could this possibly be fuel injector related?
Old Sep 24, 2002 | 07:59 PM
95TEGyoure it
Billy Sexcrime
usually when you change the spark plugs, you also change the spark plug wires....at least that is what i do
try changing those first....
Old Sep 25, 2002 | 07:46 AM
ChillOutWayne
i honestly dont think that this problem has anything to do with spark plug wires, especially since it ONLY occurs when the engine is cold when i first start out...but yur right, i need to do those anyway...thanx for the adivice, anything else would be appreicated
Old Sep 25, 2002 | 10:57 AM
brancato1's Avatar
brancato1
Great Taste, Less Filling
Do a compression test on the motor whenever you get a couple of minutes. My old 95 GSR did that, and when I did the comp test, my cyllinders were doing 200 psi (good), except for one, which was doing 120 (very bad). Find out your compression, and go from there.
Old Sep 25, 2002 | 03:08 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
The compression is good on his motor, It seems to be the injectors, it is almost a 'lack of fuel' stutter, we'll check it out!
Old Sep 25, 2002 | 03:56 PM
ImportRac3r's Avatar
ImportRac3r
Elite Member
Hey man....I had the same problem a couple weeks ago.. What u do is change your oil asap and get a tune up and it will fix u right up. peace
Old Sep 25, 2002 | 05:23 PM
likaciv's Avatar
likaciv
What was that?
Old Sep 25, 2002 | 08:44 PM
thx247's Avatar
thx247
vaccum line cant cause something like this?
