Odd Engine Hesitation...
Old Sep 26, 2002 | 05:08 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
No we checked the vacumes are all good:thumbup:
Old Sep 27, 2002 | 09:56 AM
stickboy's Avatar
stickboy
Default compression test
<<Do a compression test on the motor whenever you get a couple of minutes. My old 95 GSR did that, and when I did the comp test, my cyllinders were doing 200 psi (good), except for one, which was doing 120 (very bad). Find out your compression, and go from there.>>
i have the same problem on my '95 gsr. when sitting in traffic and the gas pedal slightly depressed the engine doesnt know whether to go or stop. how do i do a compression test?
Old Sep 27, 2002 | 10:09 AM
stickboy's Avatar
stickboy
Default ecu test
how do i do a ecu test to check for any codes? btw. car is well maintained with all plugs, gas filter, wires, cap... blah blah... it has been changed... even the pcv. ran three bottles of fuel injector cleaner thru during one tank. when i get up on it... its ok... only when stop and go in traffic. please advise.
Old Sep 27, 2002 | 01:19 PM
likaciv's Avatar
likaciv
compression checks out
:thumbup:
Old Sep 27, 2002 | 03:59 PM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
Default Re: ecu test
uhh 3 fuel injector cleaner bottles in one tank?!?!? is that even good for you injectors???? don't quote me on this, but that just doesn't sound right to me....
i also hear that fuel injector cleaner isn't even good for all fuel injectors....someone know?
Old Sep 27, 2002 | 06:09 PM
reech-around's Avatar
reech-around
RIP Woong.
i had the exact same problem. new O2 sensor fixed it for me
Old Sep 28, 2002 | 10:13 AM
stickboy's Avatar
stickboy
Default o2 sensor
rich. thanks for your post. who put in the new 02 sensor for ya? is that something i can do or should i bring it to a garage or acura dealer? thanks again
Old Sep 28, 2002 | 02:26 PM
likaciv's Avatar
likaciv
you could do it easily :thumbup: no need to pay for 75$ an hour labor.
Old Sep 28, 2002 | 03:02 PM
stickboy's Avatar
stickboy
Default o2 sensor
instructions (where is it and I heard there are two of them) would be greatly appreciated.... and where do I buy the replacement? local automotive store?
Old Sep 28, 2002 | 10:58 PM
ChillOutWayne's Avatar
ChillOutWayne
im gotta do that anyway cause i put in a testpipe and i may have jacked up the O2 sensor anyway...from the 94-97 there is only one but the newer ones have 2 casue of the OBD2 setup...but u can get them at local stores or at honda...but there are different types, honda wants like 300 for the original and like bosch wants like 50 for a generic...my new question is: is the generic gonna do the same job as the expensive one?
