96 rs using hi octane
Old May 16, 2006 | 04:55 AM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
Default 96 rs using hi octane
for the past two months ive been running my 96 rs on shell hi octane i was told its good for the engine and gives it a little extra pep, is this tru?
are there any pros or cons whenit come to this ?
Old May 16, 2006 | 05:19 AM
Nors's Avatar
Nors
倍力恋
As far as I know on integras that is false. I may be wrong because the new accords when running higher octane will advance the spark, providing better performance. But I do not think integras do this, therefore you are wasting money. Stick to what your owners manual says, unless you have some pinging and knocking then premium would eliminate the issue.
As of right now your actually hurting performance because higher octane gas have less BTU's per gallon then lower octane gases.
Old May 16, 2006 | 05:22 AM
JLO's Avatar
JLO
so stop putting the good stuff in ?
Old May 16, 2006 | 05:29 AM
Nors's Avatar
Nors
倍力恋
If it is a stock engine (ie. no forced induction) do what the owners manual states.
I know GSR's require premium, but to my knowlege RS's do not.
Old May 16, 2006 | 06:21 AM
JLO's Avatar
JLO
is it bad for the engine though, am i hurting any parts by doing this?
Old May 16, 2006 | 06:33 AM
Nors's Avatar
Nors
倍力恋
Just your wallet and performance.
Old May 16, 2006 | 07:58 AM
g290ls's Avatar
g290ls
they call me tater salad
the myth i heard was if you do put the higher octane in on road trips, it helps to clean the injectors and increase the mpg ratio by a few more miles to a tank, buts thats what i heard...
Old May 16, 2006 | 08:07 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Stick with regular gas (87 octane).
Every 9-12 months, add the correct quantity of fuel injector cleaner.
It will be significantly cheaper in the long run and you won't risk a thing.
Old May 16, 2006 | 08:47 AM
Joe's Avatar
Joe
You're just wasting precious valuable money.
Old May 16, 2006 | 08:38 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Higher octane will only benefit you if the car is tuned to take advantage of it.
Like if you had a high boosted setup tuned for race gas, it would make more power because the ignition could be advanced far beyond what it ever could with pump gas.
Essentially, you are wasting your money.
