Turbo GSR
Old Apr 26, 2006 | 06:36 PM
1turbodc2's Avatar
1turbodc2
got boost?
Originally Posted by westcoaststyle
turbo & sc are both boost :thinking:
I say turbo all day long. :yes:
haha sorry, your right they are but JRSC i don't consider it as boost
Old Apr 26, 2006 | 09:07 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
You don't have to lower compression to run a turbo...
Doesn't it depend then? I always thought you did. But if you turbo a car with a high psi turbo, wouldn't you have to lower the compression. Correct me if I'm wrong but, isn't there a connection between the engine's compression and the rpm's. This is my logic, NA cars usually rev high and fast because of their high compression (and igntion system but for our sake, lets just stick to compression), whereas, turbos take longer to rev up. I always thought that turbos take long to rev up because the compression is low or it has to be lowered so the turbo can be used to its capabilities. Please, if I am wrong in anything, correct me. The last thing I would want is to mislead someone with inaccurate information.
Old Apr 26, 2006 | 09:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
PSI and rpm doesn't matter with higher compression motors. The fuel octane is what really matters. A high boost setup can easily be done on high octane if race fuel is all that it runs along with a methanol or water injection to cool intake charge and retard combustion a bit. This will help curb detonation. Most turbo setups prefer low compression because it will make tuning and avoiding detonation easier on pump gas.
And compression has nothing to do with spool up time. There has been a test done on honda-tech that confirms this.
