tire wear
Old Apr 21, 2006 | 06:45 PM
AILS91's Avatar
AILS91
Default tire wear
on my front two tires the inner part of the tire is worn down pretty good, Is it possible to take the tires off the rims and put on the opposite sides so that the warn part is on the outside until I can afford to replace my struts, put in camber kit and pay for an alignment?
Old Apr 21, 2006 | 08:49 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
How bad is the wear?
If you can see the wires and fibers of the inner tread, then the tires must be replaced. A blowout at speed can lead to loss of control and a potentially catastrophic crash.
Old Apr 21, 2006 | 10:08 PM
AILS91's Avatar
AILS91
Not that bad...cant see the metal yet so it should be okay for a few more months..I hope....
Old Apr 22, 2006 | 02:17 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Go and get an alignment, your toe might be off along with your camber.
Old Apr 22, 2006 | 04:08 PM
AILS91's Avatar
AILS91
checked them again today and noticed on the drivers side that there is metal showing and checked the right side it's worn down but the left side is worn alot more...just ordered 2 tires for the front today...
Old Apr 22, 2006 | 06:20 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You can have the tires flipped so long as they are not directional. Some tires are designed to only travel in one direction due to tread design and functionability. However this is not a good idea as you are now placing a weaker portion of you tire to the outside which can cause it to roll off the rim during a turn if there is not enough meat on the tire to actually count as a tire. That and your traction stability will be significantly decreased.
Old Apr 22, 2006 | 11:52 PM
Phateless's Avatar
Phateless
S2K compatible
most shops only charge $50 for an alignment. that should take care of irregular tire wear, unless your car is dumped 3 inches
Old Apr 23, 2006 | 07:51 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
An alignment is going to do very little good for this guy if he needs struts & a camber kit. Forgot to ask if the car is lowered? Is it? Without an alignment kit, if one is needed the degree of the alignment will be limited and most shops will tell you that before they even place it on the rack. Then you say, but I have a camber kit installed!!! Then they are like, oh ok...nevermind. If money is tight try to finance your parts though www.sportcompactonly.com don't get carried away though.
