Weird Idle in my 95 Integra LS
Old Apr 9, 2006 | 09:59 AM
coltank's Avatar
coltank
Originally Posted by DezertMachine
How hard is a v-tec swap for my ls?
Depends on whether you have the right tools and know how, but it's pretty straight forward. I'm sure there are some DIY threads here somewhere, or you can google it
Old Apr 9, 2006 | 01:30 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Originally Posted by coltank
The IACV is an easy fix, but if you're check engine is on, you need to find out what the code is. Most auto parts stores nowadays will pull your codes for free
Every auto parts store I've been to to check my CEL out for me has said they can't do it because I have OBD1. Since your car is a 95, I'm sure you're in the same boat...Just check the Integra FAQ thread to find out how to get the CEL codes yourself.
Old Apr 9, 2006 | 06:59 PM
rage469's Avatar
rage469
the idle air control valve is almost certainly the problem as long as there is no check engine light along with the idle surge. you have two options... go and buy a new iacv or bypass it by running the coolant hoses that run into it together. Trust me it works. Dont know about in colder areas though. Pretty useless in texas though
Old Apr 9, 2006 | 10:54 PM
Phateless's Avatar
Phateless
S2K compatible
that's what makes your car idle higher for cold starts?
Old Apr 10, 2006 | 12:07 AM
R_Squared's Avatar
R_Squared
LEVEL UP
no I believe that's the FITV (Fast Idle Thermo Valve).
Old Apr 10, 2006 | 06:58 AM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
K im sorta new at this.....so as far as you know its not a big deal right?and what do you mean by i need to get a code can you explain this to me, what happens if i dont get this code?
Old Apr 10, 2006 | 11:05 AM
Phateless's Avatar
Phateless
S2K compatible
if your check engine light is on, the car's computer is telling you something is wrong. there is a code to tell you what area the problem is in. you need to find out what code it is. it's like you say ow, then tell the doctor your arm hurts. get it?
Old Apr 12, 2006 | 09:26 AM
coltank's Avatar
coltank
JLO has a 96
