teg qualitys
Old Apr 5, 2006 | 08:47 AM
  #41
sherwood's Avatar
sherwood
I missed Sean
You don't NEED premium gas....its just recommended
no, no, you need it.
the knock sensors in the c1 and c5 will bring down the engine so it wont detonate with 87 but it's not a good idea.
Old Apr 5, 2006 | 09:56 AM
  #42
BtTurboM3's Avatar
BtTurboM3
great so you have to but premium gas in it? that will be great when gas prices are right under $3.
Old Apr 5, 2006 | 10:20 AM
  #43
sherwood's Avatar
sherwood
I missed Sean
only for the gsr ir type-r, as for the ls that'll take regular
Old Apr 5, 2006 | 11:33 AM
  #44
BtTurboM3's Avatar
BtTurboM3
o ok cuz most likely i will get a LS. i want to pay as little on gas as possible.
why do GSR and Type R's need premium?
Old Apr 5, 2006 | 11:36 AM
  #45
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
The knock sensors....if the gas is too low in octane it starts misfiring so it lowers the timing..but it can only lower the timing so far since the GSR is "performance" car
Old Apr 5, 2006 | 11:37 AM
  #46
BtTurboM3's Avatar
BtTurboM3
o ok well i dont think i need to worry about that. thanks
Old Apr 5, 2006 | 11:56 AM
  #47
Phateless's Avatar
Phateless
S2K compatible
they need premium because they're higher compression with advanced timing. if the octane is too low, the mixture could explode too early in the cycle and blow up your engine. so if the manual says premium, on any car, USE PREMIUM!!!
Old Apr 5, 2006 | 11:57 AM
  #48
sherwood's Avatar
sherwood
I missed Sean
no the reason they need premium gas is their high compression ratios, they need the octane to prevent ignition from heat and compression.
the knock sensors are there only as precautions to prevent engine damage due to pinging, knock, detonation, whatever you want to call it it's all the same, the fuel burning at the wrong time due to any number of factors.
Old Apr 5, 2006 | 02:26 PM
  #49
BtTurboM3's Avatar
BtTurboM3
o ok that makes a little more sense now.
