Once camber adjusted?
Old Mar 27, 2006 | 07:01 PM
kartman2's Avatar
kartman2
Default camber
Yes, when I got the car it had the original struts and cheap skunk sleeves
with those out of whack numbers. Since then I have replaced the springs
and struts, bought new tires and am having the camber plates installed.
After installation I'll have the alignment redone. I'm hoping all this will
give car a suitable ride.
I wish I had been more careful about buying this particulor used car.
I could of done much better, a lesson well learned.
Old Mar 27, 2006 | 07:57 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Well, you live and learn. :hs:
Just keep in mind that with your current setup, the firmness of the shock is what's going to reduce body roll the most.
The camber plates are there to re-establish a proper alignment so the tires wear at a "normal" rate.
