Need more head room
Originally Posted by mr.crx
i dont think your getting it yes you could modify the brackets. but then it becomes to unsafe they are that way for a reason. if you are really that bothered by it you can just have new seats made like said before and the will take the spot of oem seats. or you can have del sol seats matched up. but anything other then that would be considered unsafe and is not recomended.
I just hope it doesnt cost an arm and a leg to have the Del Sol seats match my interior.
Originally Posted by Ub3r-L33ch
Ok, I will take that in to consideration, can it be done?
I thought I stated my position clearly. Regardless of whether modifying the frame is possible or not, I would not do it due to safety concerns. If a weld joint were to fail, the seat could come off the frame rails in a crash. The consquences would be gruesome. :ugh:
...I'd probably be fine with this if I can have the seats stay they color they are.
Right now my seats are gray leather. So it doesnt really matter what kind of seats they are so long as they are leather and match the interior, be it Del Sol or racing.
What do you guys think of these:
http://cgi.ebay.com/ebaymotors/Sim-L...spagenameZWDVW
Going by what it says I think the seat cushion is 5" up from the floor, not sure what the stock ones are.
They look like pathetic knock-off of the Sparco Milano seat.
The seats aren't FIA certified, so who knows how they'll perform in a crash.
Call me a pessimist, but I'd sooner trust my life to a seatbelt made from razor wire.
I highly doubt you can modify the stock rails at all to lower the seat...everything is pretty compact as it is.
I think you might be able to get out an inch or so if you had a shop rebuild the brackets on the bottom. like these guys said you should be careful about doing something like that, but if you go through a shop accustomed to building saftey equipment for cars like roll cages they should know how to do it correctly. I wouldn't start going at it with the MIG in the basement...
