strange squeak
Old Mar 3, 2006 | 05:03 PM
R_Squared's Avatar
R_Squared
LEVEL UP
delete...double post.
Old Mar 3, 2006 | 06:01 PM
nemesis2's Avatar
nemesis2
Originally Posted by red94teg
I think I've narrowed my problem down. I'm pretty sure my squeak is actually from my exhaust manifold. I think somewhere along the header there is a gap, possibly between the header and A pipe, which is causing the exhaust to rattle and squeak. Any ideas on how to fix this?
Listen, you might wanna have your header gasket replaced. Based on what you say about the rattling, that's the only thing you might have to change. And hopefully, your problem should be fixed.
Old Mar 3, 2006 | 06:16 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Are you referring to the gasket between the header and the head?
Old Mar 3, 2006 | 06:23 PM
nemesis2's Avatar
nemesis2
Yes, that is correct.
Old Mar 3, 2006 | 07:30 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
if it was some sort of exhaust leak... even if it was early in the exhaust track (like the header)... then it would have more of a rhythm to it... generally a leak is more of a "pfft pfft" ... also i'd imagine it would only squeak or whistle when at high rpms and the air is moving fast enough to make a whistle/squeak. i would suggest checking out your belts one last time... and see what you can do about a a/v clip of under the hood...im really curious
Old Mar 3, 2006 | 07:47 PM
Driverman5777's Avatar
Driverman5777
I'd say belts or pulley bearings.
