skunk2 vs Blox cams.
Old Feb 24, 2006 | 10:50 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by rugsr
are the skunk2's stage 2's bad for a turbo GSR?
If you have the excessive overlap tuned out with cam gears on a dyno, they would make a killer turbo cam.
Old Feb 24, 2006 | 12:18 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Originally Posted by dubcac
I swear I said that already????
The skunk2 state 2's outperform the toda b's on every dyno chart I've seen, and can hang with Spec D's...theyre good cams. And again, cams don't have lopes....they have lobes.
I never said the skunk2's stage 2's were a bad cam, i've seen them out perform the toda B's and Even run neck and neck with the C's although toda or blox was my next choice, i have no timing to spare, going with the s2s2's is what i have to do now, later down the line i might switch but in any case i'm excite to see what they'll do specially on my motor, the skunk2's i have only seen been beat by one cam.. the BC IV's same setup i have just with a bigger TB, and better header made almost 8 whp+ overthe stage 2's in his R motor..
Old Feb 24, 2006 | 02:29 PM
rugsr's Avatar
rugsr
How do my taillights look
english man, or should i say dummy terms please. So all i need is the S2 stage 2 cams and cam gears and proper tuning?
Old Feb 24, 2006 | 04:18 PM
Provocateur
On permanent hiatus
How about you continue this discussion in PM with me instead of hijacking someone else's thread?
Old Feb 24, 2006 | 07:09 PM
dubcac's Avatar
dubcac
I
Just get some turbo grind cams, you'll be much happier. I doubt you would be able to tune the cams enough to not have overlap.
