Skunk2 test pipe
Old Feb 21, 2006 | 12:10 AM
sk8ps's Avatar
sk8ps
Default Skunk2 test pipe
This weekend I am going to the track and want to put a test pipe on just for a few runs. I have a 99GSR (obd2) and the factory cat has 2 02 bungs. The skunk2 test pipe I have only accomodates one. The questions are....Should I weld another bung on, should I do the temporary tinfoil trick as mentioned in several other threads, or just zip tie it up for the several runs? If I zip tie it up and the cel light comes on will the comp go into a protection mode?
Old Feb 21, 2006 | 08:45 AM
dubcac's Avatar
dubcac
I
Your factory cat should only have one o2 bung in the rear of the cat...the other is in the header.
Old Feb 21, 2006 | 08:51 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The 94-99 GSR has both bungs in the cat.
Old Feb 21, 2006 | 09:29 AM
dubcac's Avatar
dubcac
I
You mean 96-99.
I forgot about that...I'm stuck in LS mode. h:
Old Feb 21, 2006 | 09:44 AM
Provocateur
On permanent hiatus
You mean 96-99.
Well, sort of. The 94-95 GSR has the primary O2 sensor in the cat as well, but it doesn't have a secondary O2 sensor, so that would make my last statement partially false.
Old Feb 21, 2006 | 02:35 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
yes well the CEL will turn on, it wont do anything if the primary is in the cat, if u remove it ur a/f will be off and u might even LOSE power
Old Feb 21, 2006 | 04:22 PM
sk8ps's Avatar
sk8ps
Default ...
Thanks for the response but I still dont have a clear answer. I know my cel light will trigger, and I now know my A/F will be off... What I need to know is if I should I take the time to weld another bung for 4 or 5 runs down the strip or if the tinfoil trick works as a temp fix..thanks.
Old Feb 21, 2006 | 05:14 PM
dubcac's Avatar
dubcac
I
If it was me, I'd weld a bung for future use. The tinfoil trick will be fine for a few runs though.
