annoying squeak
Old Jan 28, 2006 | 03:51 PM
PurpleHaze's Avatar
PurpleHaze
Default annoying squeak
ok ...heres a question, i did my brakes on the teg. Front and rear, changed the pads , rotors, pad clips,bled the brakes, lubed everything up .......squeak squeak squeak. Took apart the offending brake assembly, cleaned and lubed the guide bolts, reassembled it all, .....squeak, squeak blasted squeak. What am i missing? What's making that blasted squeaking noise. I hear it at around 5-10 mph , it stops when i apply the brakes or above 10 mph.
Old Jan 28, 2006 | 04:02 PM
Got_my_air_on's Avatar
Got_my_air_on
I have the same problem, but when i go faster so does the noise, its like it squeaks faster and faster and faster...lol
Old Jan 29, 2006 | 07:37 AM
newgsrdriver's Avatar
newgsrdriver
First make sure a dust shield isnt making contact with the rotor.
Second make sure the pad is installed correctly, IE the dot on the pad mates with the caliper. If not, the pad will sit crooked and make contact with the rotor as its turning.
Third, make sure you applied permatex to the back of the pad.
Judging by your symptoms, sounds like #2.
Old Jan 29, 2006 | 11:29 AM
PurpleHaze's Avatar
PurpleHaze
Thanks... Im' gonna check out the things you suggested. It seems like it's getting a bit quieter now, but from time to time...... Nothing worse than trying to cruise by and getting attention because of the squeak.....lol
Old Jan 29, 2006 | 11:55 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
What kind of pads did you use?
Cheap pads will most likely squeak no matter what you do.
