car is running crappy
Old Jan 26, 2006 | 11:09 AM
hachacker5024's Avatar
hachacker5024
Default car is running crappy
i just installed my new valve seals and stuff like that i had taken my timing belt off when i took the cams out and i have all the marks lined up the way it is in the book but when u start the car it starts right up but the car is running like CRAP just is stuttering and the car wont rev up so i was thinking that i need to either adjust the timing with a timing light or adjust the ignition but wasnt sure do you guys have any thoughts
Old Jan 27, 2006 | 08:15 PM
nemesis2's Avatar
nemesis2
Listen man take it from me sorry to say this but your timing is way off and personally if i were you i would not drive the car around like that. Have the engine looked at by someone who is pretty good at timing adjustment. Cause you could be causing a lot more harm to your motor so don't risk it.
Old Jan 27, 2006 | 08:20 PM
Patman015's Avatar
Patman015
Gold Member
^^^^^^^^^^^^^^^ DEF listen to this man! The timing belt isn't the only thing to get messed up when replacing valve seals. Cam timing and valve timing are very crucial, and I recommend starting over. Assuming you did everything besides the timing belt correctly, the least I would expect to find AFTER you did it is a bent valve. Good luck man, valve seals are supposed to be sinchy, but if you don't fully understand engine and cam timing, its really hard!!
