is it worth it?
Old Jan 8, 2006 | 11:10 PM
gsr converters's Avatar
gsr converters
Default is it worth it?
i know this has been pretty much covered but i got an 89 ls integra w/ a jdm b16a1 swap and i have a gsr94. i want to put the gsr head on the ls. i plan on haveing it professionally done. how much more horsepower should i see when this is done. how much will i be spendinng and do you guys think it will be worth it? and should i upgrade the ls tranny to a gsr, would that be better?
Old Jan 8, 2006 | 11:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will lower compression, so you what it loses in compression, it will make up with the better cams. Definitely not worth it. I like your idea of upgrading the tranny, though.
Old Jan 9, 2006 | 12:55 AM
gsr converters
wouldnt be worth it to change the ls to vtec?
Old Jan 9, 2006 | 04:36 AM
sherwood's Avatar
sherwood
I missed Sean
schmoo, wont swaping the pr3 for the p72 raise compression?
and the ls with the swap already has vtec, it's got a b16, it no longer has an LS b18b
if you plan on buying an ls bottom end and putting your gsr head on it, if tuned right you should be looking at around 170-190, but as schmoo and others will tell you i'm sure, boost is by far the best bang for your buck. if you want to be an individual, i'd go N/A with a bored c1 or c5 bottom end and a ported p72 head. upgrade the bolts and pistons add some extra stuff in there and then you should be looking at around 200+WHP of course this will cost around 7-8k to build
Old Jan 9, 2006 | 05:42 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I would not start wrenching on the 89 too much. Unless it is fully rebuilt in a lot of aspects. I'm thinking a lot of it still has stock parts on it, that may be original. I use to have an 89 w/a fully built zc motor and tranny. The poor thing started to fall apart from kicking down on the throttle so much. Maybe it will be different for you, but I would advise blowing so much $$$ on an old car that may start giving you problems if you start pushing it. IMO.
Old Jan 9, 2006 | 09:32 AM
Provocateur
On permanent hiatus
Yeah, you are right. I had it backwards. A B16 or B18C5 head will lower the compression when put onto a GSR block.
Old Jan 9, 2006 | 09:42 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
even professionally done... w/ the amount of money you'd end up spending (especially having it done professionally), would mean that you could boost, or have your GSR tranny... personally i think the tranny would be your best spending area right now
Old Jan 9, 2006 | 05:38 PM
gsr converters
thanks for the info. The motor in the ls only has about 30,000 miles on it. Its only a 1.6 non v-tec and it seems like it could beat my gsr which has 133,000 on it. Im selling the ls to a friend and he wanted to know what could be done to make it faster and im getting a c5 for my gsr so i was trying to make use of the old motor.
Old Jan 9, 2006 | 05:40 PM
gsr converters
the motor is supposedly pushing 160hp. bought it from noyan usa in virginia
Old Jan 9, 2006 | 05:43 PM
kiddcarbuff's Avatar
kiddcarbuff
swap the gsr into the 89??????? since it has a b16...jsut swap the whole motor ecu etc...obd1-obd0 my $0.02
