Timing belt install next week
Old Feb 3, 2006 | 11:44 PM
  #81
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
^ or he can go get the helms manual... or the TI and the cspeed racing are both perfect
Old Feb 4, 2006 | 06:17 AM
  #82
rugsr's Avatar
rugsr
How do my taillights look
ye it was a big help, perfect IMO
reason why the bolt wouldnt come off is cuz Buffalo snow is crazy and and the salt here is worse.........come to think of it, i think its snows more SALT then it does actual snow!!!!!
dang you used a 3/8 extension.....my 1/2" Husky broke
good thing Husky has a life time warranty on their tools
Old Feb 8, 2006 | 05:05 PM
  #83
rugsr's Avatar
rugsr
i would have scanned them but they are dirty. just right click save and zoom in using windows
have fun, if anyone else needs info let me know
Old Feb 15, 2006 | 05:10 PM
  #84
rugsr's Avatar
rugsr
doing valve adjustment next week. wish me luck! any advice or tips
Old Feb 15, 2006 | 06:48 PM
  #85
VPUPPY's Avatar
VPUPPY
Just make sure you get or have an angled feeler gauge.
Old Feb 15, 2006 | 07:25 PM
  #86
rugsr's Avatar
rugsr
like the ones u check spark plug gaps with? its a circle?
Old Feb 15, 2006 | 07:34 PM
  #87
reno96teg's Avatar
like so..
Old Feb 15, 2006 | 07:39 PM
  #88
rugsr's Avatar
rugsr
ah ok, thanks!
Old May 19, 2006 | 05:30 AM
  #89
kevyt's Avatar
kevyt
Originally Posted by Däs Schmoo
If you can't get it off with an air ratchet or with a breaker bar while the car is in 5th gear and someone on the brakes, you can take it to a shop and have them loosen it and then retorque it enough to get you home.
Thanks for that advice. I tried several times with a strap wrench and I was unable to break the bolt loose until I read the 5th gear trick
- Sprayed PB Blaster on it the night before.
- Placed the car in 5th gear.
- Wedged the 2 feet long jack handle between the brake pedal and the bottom of the seat (steel part of the seat) which placed pressure on the brake pedal.
- Placed a strap wrench on the balancer and it wedged itself against the axle.
- Placed a breaker bar on the bolt and it broke loose with my foot.
The strap wrench did not work without the 5th gear trick. I think the combination of wrench and the 5th gear trick did it.
Thanks,
Kevin
Old May 19, 2006 | 07:13 AM
  #90
rugsr's Avatar
rugsr
ye the 5th gear trick and someone on the brakes works wonders!
