Timing belt install next week
Old Jan 29, 2006 | 04:24 PM
  #71
FooD2000's Avatar
FooD2000
Still Water
finally... *rolls eyes
Old Jan 31, 2006 | 06:08 AM
  #72
rugsr's Avatar
rugsr
How do my taillights look
IT IS FINISHED!
well almost, pics and one more question/bolt to come........
Old Feb 1, 2006 | 10:49 AM
  #73
rugsr's Avatar
rugsr
ok well here are the pics, enjoy
dont loose that KEY!!!
looking from underneath
this must come off to get the bottom cover off
w/o bottom cover
make sure these are lined up!
do you have all your parts? Only thing I didnt use was the new pump gasket. the old one was thicker and fit way better, and was still looking good. the new one fit crapy and kept falling out of its groove.
what i did here was mark the top tooth with white out the place the new belt ontop of the old belt and mark the 2 teeth on the sides of the top tooth. this way i will know that i am not a tooth off!
even though the rad. was drained and removed along with other lines, there were still some fluid left. make sure you put somethere to catch it so it doesnt ruin your assphalt like it did mine
keep bolts in thier proper "place". some are different lengths
remove this for better access, BTW i kept the PS line there, and had no problem
slack before proper tension
as you can see my marks are off by one tooth, BUT they are both off which means IM GOLDEN!
that pic is with proper tension. what you must do is tighten the teinsor pulley and crank the motor over 6 times. then loosen the teinsor bolt and watch the pulley tighten the belt up. then crank it down to 40lbs.
Ill be posting the whole process from my haynes manual VERY SOON
This pic is of the bottome cover bolt. I BROKE IT and will be trying to replace it. i probably wont need to but im anial like that
if anyone has questions PM me or type some here
Old Feb 1, 2006 | 11:09 AM
  #74
reno96teg's Avatar
^ nice.
Old Feb 1, 2006 | 12:52 PM
  #75
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i like the idea of the date and mileage... congrats on finishing... good luck w/ future shit
Old Feb 2, 2006 | 10:28 PM
  #76
b00gers's Avatar
b00gers
Thats great. I will be doing the same thing soon with a couple of friends. :hs:
Old Feb 2, 2006 | 10:30 PM
  #77
dubcac's Avatar
dubcac
I
Originally Posted by honura
Just a thought and all I did was skim through the complete post. But you can not use an extention when trying to take off the Crank bolt. When you do this it makes all the power go right into the extention. I would go back to using an impact socket and the breaker bar/rachet, with the 4 foot pipe. I guess the longer the better on the pipe. Tell your friend to hold the brakes down extremly hard. Sorry if it sounds stupid or if you have already tried it. But this is the only way if the gun does not work.
That's funny, I've used an extension every time I've done the crank pulley bolt...and long enough to stick out past the fender too.
Old Feb 2, 2006 | 10:41 PM
  #78
Provocateur's Avatar
Provocateur
On permanent hiatus
I used an extension too. It put some strain on the little 3/8" extension, but the bolt came off with no hassles. I guess it helps that there is no such thing as rust in socal.
Old Feb 3, 2006 | 04:06 AM
  #79
bnuk's Avatar
bnuk
yeah I don't usually use one but using a half in. extension shouldn't matter since there is already like 90 degrees of flex between the brakes and the crank.
Old Feb 3, 2006 | 06:39 AM
  #80
KarrNtegGSR's Avatar
KarrNtegGSR
Default Buy the sevice manuel.
Originally Posted by rugsr
Well its time. Ill be doing the timing belt next week.
Ive searched this topic here for bout an hour and on team-integra too. i also have the hayes manual, print outs and pics so im good to go. ONLY THING is, i couldnt find how to adjust the valves and do i need to. its a 95 GSR with 91k in good running condition. any info is welcomed. thanks
BTW what is TDC, i see it mentioned a lot but what is it
buy the service manuel it will take you through the steps. It should be in the back of your owners manuel where you can order it.
