cam gears while doing timing belt
Old Jan 6, 2006 | 06:42 PM
rugsr's Avatar
rugsr
How do my taillights look
skunk2 huh.....NOT AEM right?!
Toda are like 300 but i hear they can ruin your org cams.
Old Jan 7, 2006 | 09:18 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
AEM is a quality cam gear as well, i have yet to hear anyone say anything bad about it... but i prefer skunk2... seen several friends cars with them on there and nothing ever went wrong
Old Jan 7, 2006 | 05:39 PM
rugsr's Avatar
rugsr
cam gears and stock cams is pointless right......mabye i should wait for more $ and get different cams next yr
Old Jan 7, 2006 | 08:05 PM
tegbooster's Avatar
tegbooster
basically....i was under the impression you already had some, they can do wonders if your going thru the full tuning process... just makes it easier on the tuner to adjust timing
Old Jan 8, 2006 | 02:49 PM
rugsr's Avatar
rugsr
ah, any likeness to a certain cam. I think i heard once that skunk2 cams are bad for turbos, could be wrong, but what would be a good cam for a boosted GSR?
Old Jan 8, 2006 | 02:55 PM
97civicEXVTEC's Avatar
97civicEXVTEC
skun2 makes turbo cams so im guessing they are not bad for turbos. what are your hp goals? you dont really need a cam, a gear will be just fine. i have also heard that ls cams are the best oem cam for turbo.
Old Jan 8, 2006 | 02:58 PM
tegbooster's Avatar
tegbooster
skunk2 does make turbo cams...but they do not make turbo (non vtec) cams... they only make the turbo cams for the GSR applications
Old Jan 8, 2006 | 09:05 PM
rugsr's Avatar
rugsr
turbo cams for GSR is good for me
HP goals.....well id like to be at 300WHP, daily drive @ 8psi
track @ 10psi
Ive seen one turboed teg running 7psi with the same setup as me and his dyno was 290WHP i believe so i think i can hit this. But if getting Skunk2 turbo cams and cam gears will put me well over 300 for a decent price then ill do it. OR upgrade the suspension and get ready to by a new clutch and flywheel
Old Jan 8, 2006 | 10:58 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You will see minimal gains out of properly adjusted cam gears on your stock cams, so unless you upgrade the cams, they wouldn't worth your time or money.
Despite what everyone says about running an N/A cam on a turbo car being bad, they are wrong. If you can tune the overlap out with those cam gears and properly upgrade the valvetrain, they will make a lot more power than those shitty turbo cam offerings. If you don't feel like taking the risk and believing me, the CTR cams I am running on my setup are a huge upgrade that would definitely benefit from some cam gear adjustments.
Old Jan 9, 2006 | 07:51 AM
rugsr's Avatar
rugsr
price on that schmoo?
