installing a system: 2000 integra 2 door
Old Jan 8, 2006 | 10:09 PM
b00gers's Avatar
b00gers
Originally Posted by sai402
ok so it should fit a 4 guage power wire with no problem, right? and the wire would come out from under the glove box, correct? if its like that, i will do it tomorrow morning after i wake up. i read also on the thread of ppl that wants to know what kind of equipment they got, heres mine:
kenwood kdc-x915 excelon HU
all Monster Cable wire/RCA
single 12" JL audio W7
2 set infinity (reference) 6010cs 6.5" component speakers
4 channel kenwood excelon amp
2 channel kenwood excelon amp
1/2 faret monster cable capacitor
4 way power distributor
Model of the amps?
Old Jan 8, 2006 | 10:10 PM
b00gers's Avatar
b00gers
Originally Posted by jragon
I would suggest that you run another 4 gauge cable, one for each amp especially if you are most likely placing the amps in the hatch area behind the rear seats. .
It is hard to say without know exactly what amps he will be running.
And its not farets, its farads. And you dont pair up the caps with the subs, they go with the amps that are feeding the subs. s
Old Jan 8, 2006 | 10:12 PM
b00gers's Avatar
b00gers
In addition to upgrading the ground wire from the battery to the chassis, you can also replace the one that goes from the engine to the chassis, and add another power cable from your alternator to your battery (fused).
Old Jan 8, 2006 | 10:28 PM
rugsr's Avatar
rugsr
How do my taillights look
hmmmmmm i dont think ive seen this hole under the battery tray. i have a 95 GSR 2dr. is it in the same place?
Old Jan 9, 2006 | 04:28 AM
sherwood's Avatar
sherwood
I missed Sean
it should be very little changed over the years
Old Jan 9, 2006 | 09:51 PM
sai402's Avatar
sai402
ok the amp is not yet purchased but im trying to install a new HU but dont know where to start to get the OEM radio out. some say there are clip that can be pry out with a screwdriver but some say that i need to unscrew some screws on where the tranny is..any suggestion or help?
Old Jan 9, 2006 | 10:15 PM
eg_bert's Avatar
eg_bert
hoooorraayy Beer
optimally you would want to go with 2 ga. wire from the battery to a fused distribution block that would then split into two 4ga. wire, one to each amp. since you have a .5 farad cap i suggest using it on the sub amp (i think the rule of thumb is about 1 Farad per 1000 watts). try this setup out and see how u like it, if you see too much dimming maybe look into an optima yellow top battery or high output altenator. for exact ga. wire check your install manual for the amp it should say what size wire you should use.... let us know how things workout,
Old Jan 10, 2006 | 02:46 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
4 screws in center console
2 under cover under e-brake
3 in the ashtray
3 behind the ashtray
2 in the back of the center kick panels (by yours and your passengers shins)
-the entire center area comes out
2 screws (very back) holding stereo into cage
-that will let the stereo come out freely...
-unhook antenna/wire harness
-wire up new one.. attach antenna..
-a dash kit is worth it ($10 at any best buy install bay/auto store)
-wiring harness will make for easy (plug and play) wiring ($5-10 at best buy install bay/auto store)
then your basically done.... for pics and a full more detailed write up... heres a link... i think they're doing this in a GSR... but all G3 stereos are the same
http://www.team-integra.net/sections...?ArticleID=115
Old Jan 10, 2006 | 07:03 PM
b00gers's Avatar
b00gers
I have no idea how some people are able to recommend the power wire gauges without knowing how much power he will be pushing with the amps. :thinking:
Old Jan 10, 2006 | 09:26 PM
sai402's Avatar
sai402
the 4 channel amp is KAC-X541 kenwood excelon series. 960 watts max
the 2 channel amp is KAC-X521 Kenwood excelon series. 1000 watts max
