need a good clutch/flywheel
Old Dec 14, 2005 | 10:06 PM
acteg's Avatar
acteg
Default need a good clutch/flywheel
need a good clutch/flywheel kit , anybody has a particular brand that they prefer over the competitors. and if so how much can i get a combo kit for and what websites are the great deals in.
Old Dec 14, 2005 | 10:09 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Search.
You get what you pay for and a clutch is not something I would recommend going cheap on.
Why do you need a stronger clutch than stock?
Old Dec 14, 2005 | 10:11 PM
jjang's Avatar
jjang
exedy clutches are supposed to be good for slighty modified daily drivers, relatively cheap but cant handle too much power from what i understand.
i was about to get a new flywheel/clutch but ish happened and i became broke...and since its xmas im broke once again.
Old Dec 15, 2005 | 07:57 AM
ACT I's Avatar
ACT I
I been told act is the best but my mechanic's buddy has his own parts web site said the exedy is doing real good at the track and exedy just started making clutches for the small boys. Its a good clutch but if your car is old having your clutch changed might be the end of your tranny. I'm lookin for tranny now b/c of that. Atleast so i've been told.
Old Dec 15, 2005 | 08:45 AM
Provocateur
On permanent hiatus
The tranny will not be affected by changing the clutch. If anything, it will shift better because a worn clutch will cause all sorts of grinding.
ACT makes some of the best clutches out there, but they are expensive.
Old Dec 15, 2005 | 09:03 AM
ACT I's Avatar
ACT I
now schmoo what about the pressure from a performance clutch will that affect the tranny cause it was a pleasure to drive 4 like 2 months then i noticed i started grinding when i hit 3rd gear. But everytime i tried to show some1 it wouldn't do it. I noticed only after i hit about 3500 to 4000 rpm an above it would happen. I could really use the help and yur always so helpful you schmoo u lol. But real rap schmoo in desperate need of help.
Old Dec 15, 2005 | 09:17 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
^^ i had the same problem, the reason nobody ever sees it is because u slow down and think about ur shifting...do the same thing when your driving and the grinding will dissapear
Old Dec 15, 2005 | 10:13 AM
Provocateur
On permanent hiatus
It may have something to do with the pedal adjustment. The clutch may not be completely disengaging when you are shifting, so it may cause some grinding. Also, check the fluid and bleed if necessary.
I have the ACT clutch and the pedal is a little firmer, but I have no grinding on the original tranny.
Old Dec 15, 2005 | 08:09 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
centerforce dfx stage 1 w/9lb flywheel.
