shifting problems (high rpms)
Old Oct 12, 2005 | 11:05 PM
subwuufer's Avatar
subwuufer
Default shifting problems (high rpms)
-A short shifter was put into my the car but it might of not been installed right (previous owner did a self install) as for some reason i cant shift at a high rpms especially when shifting from 1st to 2nd gear. I have to shift under 3500 rpms or the car will be hard to shift to the next gear and sometimes will make a grinding noise however when i ease it into 2nd gear it shifts just fine. The other gears are fine for the most part...
Old Oct 12, 2005 | 11:07 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Try buying a decent short shifter or OEM piece and replacing it. It may have just been installed incorrectly, or is a piece of crap.
If that doesn't fix it, it may be a clutch or transmission issue. Check the fluid level and bleed the clutch system. I had a lot of grinding problems when my clutch went out, so you might just need a new clutch.
Old Oct 12, 2005 | 11:23 PM
subwuufer's Avatar
subwuufer
thanx, i will try replacing the shifter asap i think the owner put a mugen short shifter in but he said the spacing was different and didnt measure to the older shifter
Old Oct 12, 2005 | 11:24 PM
subwuufer's Avatar
subwuufer
hopefully it is an easy mod i havent changed out a shifter before...
Old Oct 13, 2005 | 08:36 AM
Provocateur
On permanent hiatus
It isn't too bad, but you need to get underneath the car. If you search this site, I am sure you can find some instruction on what is involved.
Old Oct 13, 2005 | 06:25 PM
wicked_geezer's Avatar
wicked_geezer
dude i have the same problem, when i redline from 1st - 2nd that shit either grinds or gets real hard...my mechanic bleed the clutch...and that was noo good he said its just my clucth slippin so im gonna buy a new one!...im pretty sure the shifter has nothing to do with it
