m/t or a/t half shaft???????? HELP ME
Old Mar 3, 2022 | 11:46 PM
b18RT4WD's Avatar
b18RT4WD
Default Seal difference
Originally Posted by jdmeg6hatchy
what gasket?? where??? pix???
the halfshaft from 91-93 integra use the seal from the half shaft if you use a 94-2000 integra half shaft you need to use that seal if not it will cause the trans to leak from the differential hole where the half shaft connects
