does gas octane really matter?
Originally Posted by BADST GS-R
1. your link doesn't work
2. do you have proof of how much it raises the octane rating? Not the claim by NOS, but actual proof from a 3rd party...
http://europeancarweb.com/tech/0503ec_techboost/
Not bad...I'm a big fan of the "home brew" toluene fix though.
http://www.gnttype.org/techarea/misc/octanebooster.html
Originally Posted by SVT Russ
Using a fuel with "too much" octane (than the motor needs) will hurt performance also. Strange but true.
I'm running 12.25:1 compression on my gsr and I can definate feel the effects of octane/compression...
On hot summer days I can't go with anything less than 94octane or else I'll here some pinging... but in the colder months I can use 92octane without a problem, because as the temp. drops so does the octane rating that I need
I've tried 92 with booster, but it not as good as 94(the problem is I have to drive 45+ min to get it... if It wasn't so far I'd use it all the time)
if I use 100 octane I can bring up my timing to stock 16-18degrees, but right now I'm at 13-14degrees just to run 92
GSR's have a knock sensor to cut back performace if the octane is too low..so if you ran 87 it wouldn't kill the engine, I hear that you'll lose about 15% of the power, the ecu probably cuts the timing back..
