type R motor in a 93 gsr?
Old Sep 8, 2002 | 09:22 PM
93geesrrr's Avatar
93geesrrr
Default type R motor in a 93 gsr?
has anyone swapped a b17a for a b18c5 in a 2nd gen integra?
were there any problems with the cable clutch to the hydro and is it worth it
Old Sep 8, 2002 | 09:29 PM
RB's Avatar
RB
snitches get stitches
IS 20 extra hp really worth the 4-5k?
Old Sep 8, 2002 | 09:46 PM
93geesrrr's Avatar
93geesrrr
b17a is 160
the b18c5 is 200
Old Sep 9, 2002 | 08:02 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Buddy of mine swapped a B16A into a 2nd gen teg just fine. Not sure what that means for a B18C
B18C5 (USDM) is listed at 195 crank btw
Shingo
Old Sep 9, 2002 | 09:38 AM
DB7 2.0's Avatar
DB7 2.0
Banned
keep your B17!!!! u want to have a "type r" engine in there? then just put in some internal mods to it... cams, valvetrain, mild head work, ported throttle body, port match the intake manifold to the head... you already have flat top pistons which are cool but if you want to raise compression then i guess you can swap in some b18c/GSR pistons which are slightly domed.
the g2 gsr has the amazing tranny and crank/rod combo... keep it!
Old Sep 9, 2002 | 10:17 AM
qtiger's Avatar
qtiger
Old Sep 9, 2002 | 12:38 PM
red GS-R's Avatar
red GS-R
shhhh...just be quiet.
keep your engine, the only thing that makes the b18c5 better is higher compression, lighter camshafts, bigger intake manifold. if you replace your engine enternals, port polish, raise compression, bore out your intake manifold or get a racing one, your b17a will be a lot better than a stock b16c5. its not worth the money
Old Sep 9, 2002 | 12:49 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Like everyone else is saying, there's not really a reason to put a B18C5 in a G2 GSR. 5 grand for 35 hp out of a used motor is a bit steep.
But if you for some reason want to, keep your cable tranny. The gear ratios are identical so with a bit more work you can just put your cable tranny on the R motor and toss everything back in no problem.
What I would suggest rather than getting the R motor is a rebuild with high-comp pistons, new rods, lumpy cams, i/h/e, better intake manifold, etc.
Old Sep 9, 2002 | 08:27 PM
KillerB17's Avatar
KillerB17
Keep the B17. There is only one B-series motor rarer then the B18C5, and you already have it. Besides you can build the B17 to do almost as much for less hassle.
Old Sep 10, 2002 | 05:56 AM
Tobra's Avatar
Tobra
and a lot less money. Even if the motor is beat, you could rebuild it beefed up for a lot less jack.
