turbo parts info
Old Oct 1, 2005 | 10:50 PM
rugsr's Avatar
rugsr
How do my taillights look
Default turbo parts info
1 more part to go.......wastegate time boys.......heres the deal. im going with the tial 38mm wastegate but i got to choose on a spring set i want. each one has its own PSI rating, im sure you guys know. anyways my question is (pretty sure i know the answer but) if i go with a 6PSI spring can i use a boost controller to up it to like 8 or 10 later on down the road....or do i need a new spring. thanks guys
Old Oct 2, 2005 | 06:14 AM
newgsrdriver's Avatar
newgsrdriver
Nope.
Cant go lower than the spring. I would run the Tial 7.x spring, run the WG to your compressor. You'll see about 5.5PSI depending on your IC size. Then adjust up from there.
You can typically 2.5x the spring pressure and it should still hold. IE 7PSI to ~17.5.
Old Oct 2, 2005 | 07:36 AM
1995Civic's Avatar
1995Civic
I hate ricers
Originally Posted by newgsrdriver
Nope.
I believe he was asking if he gets a 6psi spring, can he use a boost controller to adjust UP to 8-10. If that's your question, you are correct. Whatever your spring is, you CANNOT go lower, but you can always go higher. But 6psi will be your base for tuning or whatever.
EDIT* Sorry if im wrong about what your were asking Just sounded like what you were trying to ask
Old Oct 2, 2005 | 07:59 AM
newgsrdriver
No you are right. And I answered what he asked. I also added in that he couldnt go lower. He asked if he needed a new spring, I answered nope, then elaborated about how the spring relates to desired pressure.
Old Oct 2, 2005 | 06:45 PM
rugsr's Avatar
rugsr
aaaaaaaaight cool. il start with 6psi. my next question is lts say i tune at 6 ight. and decide to jump to 8 or 10......whatever......dont i need to retune it. BTW you said to run the WG to the compressor......what ompressor is this. i always thought to just get a dump tube and oint it downward away from the motor......thanks guys
Old Oct 2, 2005 | 08:24 PM
1995Civic's Avatar
1995Civic
I hate ricers
You wont need to retune your motor just by going up in boost. In most cases, tuning a car for FI is to set your air/fuel ratio correctly and get the MOST power out of your mods. As long as the motor is tuned FOR forced induction, you dont need to keep retuning everytime you mess w/ your boost controller.
Old Oct 2, 2005 | 08:36 PM
tgansert's Avatar
tgansert
is all good
All this makes me wish I knew more about turbos.
tgansert teh lam3.
Old Oct 2, 2005 | 08:50 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to keep in mind that the extra boost will require extra fuel.
That said, make sure your injectors are large enough to flow enough fuel at that boost level without maxing out.
Old Oct 3, 2005 | 05:59 AM
1995Civic's Avatar
1995Civic
I hate ricers
Exactly.
Not a good thing when your robbing your car of fuel because your injectors are maxed out.
Old Oct 3, 2005 | 07:51 AM
rugsr's Avatar
rugsr
well thats good to know! I picked up the 550cc percision injectors. BTW i hear you have to wire them specialy because of resistance or ohlms or something. its not just plug and play right?
