upgrade the radiator?
well im doing the whole turbo thing and im wondering if i need to/should up grade to a better radiator. like a koyo or fluidine(SP). and if i should get one that is as wide as the OEM or a shorter but thicker one. HP might be around 290s
I am running stock temperatures with my OEM radiator.
The only reason I see in upgrading is if you feel like you need something more efficient at cooling after your stock endtanks start to crack and the radiator takes a shit on you.
Also, keep in mind that a thicker radiator like Fluidyne will require slim fans to fit the turbo manifold and misc turbo equipment. Those slim fans are not cheap, btw.
