Do I have a puncture
Old Sep 12, 2005 | 03:45 PM
raihan.f1's Avatar
raihan.f1
Default Do I have a puncture
My 94 Integra LS's front right tyre has lost 2 PSI in two weeks time where as the other tyres are still showing the recomended 29 PSI. Does this mean I've a puncture? If so ,how do I locate the puncture & fix it?
thanks,
-R
Old Sep 12, 2005 | 04:00 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
it is prob. your valve core. mine used to leak slowly like that till i bought a new one.
Old Sep 12, 2005 | 04:15 PM
raihan.f1's Avatar
raihan.f1
Hey TegMan how can I go about replacing my valve core? do u've have any links or pics to the same?
-R
Old Sep 12, 2005 | 05:06 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
first take some soapy water and apply it to your tire to see if it has any punctures in it. if it does then it will bubble. if no bubbles then take your valve stem cap off and see if it bubbles.
things you need to replace it are
valve core tool-$2
valve cores-$1
what to do
if you want jack it up
let all the air out of your tire
remove the core with the tool
put the new one in
air it up
Old Sep 12, 2005 | 06:45 PM
hey also when ur checkin for that puncture...check around the rim for a leak along where it mounts you might just have a leak there
Old Sep 13, 2005 | 10:28 AM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
thanks rebeld i forgot about that.
