grinding gears
Old Aug 18, 2005 | 07:36 PM
integra3's Avatar
integra3
Default grinding gears
i have a 91 integra and i have a slight problem, when i am shiftnig in to 2nd gear it grinds. i adjusted my linkage and it still grinds. what should i look at now
Old Aug 18, 2005 | 08:00 PM
VTEC-Power's Avatar
VTEC-Power
could be one of several according to haynes
1. Faulty transaxle
2. Faulty clutch disc
3. Release lever and bearing not assembled properly
4. Faulty pressure plate
5. Pressure plate-to-flywheel bolts loose
Old Aug 18, 2005 | 10:09 PM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
Get it fixed fast or else you'll need a new tranny. Mine started out like that and got progressively worse.
Old Aug 18, 2005 | 11:16 PM
Jeezer's Avatar
Jeezer
well, what was your problem?
Old Aug 19, 2005 | 05:57 PM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
Not sure, I can't down shift any more into any of the gears. I grind going into second and third constantly. Fourth gear no longer works. Fifth gear grinds occassionally. My tranny problems began with my second gear grinding. I checked out the shift linkage and it was fine. This all happened within a month.
Old Aug 20, 2005 | 10:59 AM
Inacurals's Avatar
Inacurals
Honda Hoar
You checked your tranny fluid level if you havent tried draining and replacing tranny fluid with Honda trans fluid right? But you knew that
Old Aug 29, 2005 | 06:37 PM
Sense-A's Avatar
Sense-A
Mentor
sounds like bad transmission.
Old Aug 30, 2005 | 05:35 AM
fjm1's Avatar
fjm1
G35
Not neccessarily bad tranny.
Try this: Go clutchless to test the tranny. Here's how you do it; Run second gear up to about 4500 RPM's. As you let off the gas shift into neutral without the clutch. Blip the throttle up to about 5000 RPM's. As the RPM's come down off of the throttle blip you should be able to slip into gear fairly easy. Remember to be smooth and don't force anything.
If you can't get the trans to shift this way you have diagnosed a synchro problem. This is bad.
If you can get it to do this it's probably just the clutch. Not so bad.
Old Aug 30, 2005 | 05:46 AM
tgansert's Avatar
tgansert
is all good
fjm1 has a good point. Try it out and don't force it. If it takes you a few tries, don't dismay. This type of shifting is a style and an art that takes practice. If you hear a small gear grind as you shift into the next gear, you may not have hit the gear at the exact moment.
You want to be able to pull the trans out of gear without clutch and a moment later slip it into the next without the clutch. I used to do this daily until I got complacent and started smelling clutch, then I stopped and use the clutch now. But... it is still the perfect way to diagnose your syncro.
GIGGITY GIGGITY GONE!
