DSM 450cc Injectors
Old Aug 15, 2005 | 05:04 PM
B18C Turbo's Avatar
B18C Turbo
Default DSM 450cc Injectors
How much wheel horsepower can DSM blue top 450cc injectors handle? Im using a t3/t04e 57 trim on a b18c1. Just wondering if these injectors are big enough for 15 psi?
Old Aug 15, 2005 | 06:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, you would want to go with something larger for 15 psi.
Old Aug 15, 2005 | 06:48 PM
B18C Turbo's Avatar
B18C Turbo
hey man, what do you think they can handle? I've heard along the lines of 300-400whp but thats a BIG range.
Old Aug 15, 2005 | 09:34 PM
Provocateur
On permanent hiatus
250-300 whp seems about right. Anything more will require larger injectors.
You want to have a larger injector than what you need just in case you want to go with more power and it puts less strain on the injector when it is running at a lower duty cycle. This will lead to a longer life and less of a chance of failure.
Old Aug 16, 2005 | 05:37 AM
B18C Turbo's Avatar
B18C Turbo
yeah man, I was just hoping to stick with 450's because there $60 vs $200. I guess I'll be sticking with this sucky FMU until I build the bottom end in December.
Old Aug 16, 2005 | 03:16 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
friend made 427 whp on his turbo type-r on the dsm injectors which i plan on running on my nitrous setup i'd say safely 300-400 whp .. before you need to replace.
Old Aug 16, 2005 | 06:01 PM
B18C Turbo's Avatar
B18C Turbo
wow thats awsome! maybe I just will use them then! Thats so awsome I am so happy now!
Old Aug 16, 2005 | 07:55 PM
dubcac's Avatar
dubcac
I
I'd go higher to be on the safe side. Maxing out the duty cycle of an injector is not something you want to do, and fuel system/management is not the part of a turbo setup that you want to skimp out on. Also, running high pressure and small injectors is a bad idea as well, because the pump loses efficiency at higher pressures, and flows less volume than needed...not to mention heating up the fuel because it's working harder. I'd go with a bigger injector.
Old Aug 16, 2005 | 09:05 PM
B18C Turbo's Avatar
B18C Turbo
thanks for the imput guys. For now an FMU, pump, and basemap will be just fine, when the motor is built in December it gets 660cc's and a dyno tune.
Old Aug 16, 2005 | 09:12 PM
dubcac's Avatar
dubcac
I
How much boost do you plan on running with the FMU and basemap?
