Broken antenna mast
Old Aug 11, 2005 | 06:09 PM
thedelock's Avatar
thedelock
Default Broken antenna mast
Does anyone know if I should follow the same instructions for replacing the antenna mast if the motor is broken? I saw in the instructions that the motor has to pull in the cord with the teeth; still possible if the motor is broken?
Old Aug 11, 2005 | 06:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The motor won't pull anything if it is bad. Check to make sure it is making noise when you turn the radio on and off. If not, you need a new motor.
To replace the motor you have to remove the panel inside the trunk to gain access and then pull it out and replace it.
Old Aug 13, 2005 | 08:14 AM
604Viper's Avatar
604Viper
my antenna is busted too, but i can't get the freakin nut off...did you have the same problem? my antenna is like, stuck part way up, so it doesn't go all the way down...i've tried a hammer & screwdriver, pliers and even snap-ring pliers like the stupid manual says, but the nut just won't budge.
Old Aug 13, 2005 | 08:34 AM
Provocateur
On permanent hiatus
The dealer should have the tool to get the nut off.
I got mine off with pliers but it scratched the shit out of it. It is only torqued to 1.7 ft/lbs, so keep trying. If all else fails, get the tool from the dealer.
Old Aug 13, 2005 | 11:14 AM
604Viper's Avatar
604Viper
yup...mines already had the hell scratched out of it =p
Old Aug 18, 2005 | 04:05 PM
Sense-A's Avatar
Sense-A
Mentor
haha i scratched mine too. i still need to replace the mast but my motor's fine. Yeah you hear it when you entirely turn off your car (radio must be on)
