lighter flywheel losing torque???
Old Aug 2, 2005 | 03:31 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Originally Posted by westcoaststyle
It dies. The engine stops running and you have to restart it.
and a lighter flywheel will do that?
That sounds like something that'd be kinda not worth...
what if you were in the middle of a run and it dropped? Ghetto...
any way to prevent that? is it just the lighter the wheel, the more likely to drop?
Old Aug 2, 2005 | 03:34 PM
dubcac's Avatar
dubcac
I
That only happens when you drop from high rpm to neutral, and the engine revs all the way down to where it would idle...it wouldn't happen during a run. I've had it almost happen to me a few times, but not often. I'm usually not going from high rpm to neutral.
Old Aug 2, 2005 | 05:44 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
I drive a little too fast, and know the roads a little too well, so sometimes I coast in neutral for a while.... any way to stop/prevent that from happening??
Old Aug 2, 2005 | 05:46 PM
reno96teg's Avatar
Originally Posted by Takumi Fujiwara
"Killing of the motor when going from high RPMs to idle" is not related to going to a lighter flywheel. You have a problem somewhere else.
negative.
yes. with a lighter flywheel, you lose some momentum over the stock, hence you increase the chance of stalling in certain situations.
Old Aug 2, 2005 | 06:44 PM
VTEC-Power's Avatar
VTEC-Power
so whats a good weight without killing the motor?
Old Aug 2, 2005 | 09:28 PM
dubcac's Avatar
dubcac
I
Ugh, like we've been saying, it only happens when you go from a high RPM to neutral, and it will drop to idle super fast. Don't do that, and you wont have a problem.
Old Aug 2, 2005 | 10:17 PM
VTEC-Power's Avatar
VTEC-Power
but still whats a good weight? 8.5lbs?
Old Aug 2, 2005 | 10:19 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I am running the 9 lb ACT Prolite and it still stalls on occasion. You will have to live with it since anything more isn't very noticable.
Old Aug 2, 2005 | 10:23 PM
VTEC-Power's Avatar
VTEC-Power
thx Shmoo you are always a great help
Old Aug 2, 2005 | 10:38 PM
dubcac's Avatar
dubcac
I
I run a 7.5lb...have had it for almost 4 years without problems.
