Help - No pressure in radiator and car is half way to overheat
There is no pressure whatsoever in the radiator. I can drive for 1 hour and still, no pressure. I can open the radiator cap without fearing it bursting.
WTF is wrong?
The collant is filled all the way to the top. I let the engine run while filling to get rid of all air bubbles, and still, the engines is halfway from overheating. No pressure build up.
WTF?
WTF is wrong?
WTF?
Water pump is toast?
Originally Posted by confucius
i do have 170,000 miles
already did the timing belt, dont know if the place that did it did the waterpump. where is the waterpump located? so i can check to see if it was replaced or the same old one.
could it also be the cap?
i dont know
i dont know
You will have to take off your valve cover in order to even begin to get to the water pump. Then ya gotta take off all the belts, which is why they're saying its a good idea to change your timing belt since you already have to take it apart. The water pump is kind of a b*tch to change.
The pump itself is easy to change, it's the timing belt mess where the difficulty is. Check the Teg FAQ sticky at the top for the Factory Service Manual download. This will walk you through the process.
