vtech controller
do you still have your catalytic converter on your teggy? they might have taken out the O2 sensor thats suppose to be on the converter but i doubt any shops are that retarded....but then again.....
btw, if the sensor is still on you might wanna check the CEL code coming from the teg
Try resetting the ECU , if the CEL is still there after a reset then try and get the malfunction indication code.
http://www.c-speedracing.com/faq/03.php
It might be intermittent failure or a faulty sensor.
yea i'd check all ur o2 censor wires make sure their in correctly and tight they could have been knocked loose when they were putting on the system disconnect your battery for about 3-5 seconds reconnect it and start your car up. this will reset ur ecu. leave your car running for about 2-5 mins. if the lights comes back on u've got a problem and will need to have your car tested for the engine code. complain to the shop who did the work because your check engine shouldnt come one from i/h/e
u going to spend $250+ on a vtec controller...then just get a Hondata s100 or s200 and u can do alot more w/Hondata than a vtec controller www.hondata.com but dont buy it straight from them buy it at a shop u can get a it for less...my buddy got his for $280 and i'm going to get one too
