Difference in gsr clusters
Old Jun 17, 2005 | 10:22 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Alright... a new policy is being implemented.
Right now and right here, starting with this thread.
There is a serious problem with threads being dragged off topic by totally unrelated conversations and questions. All of these "off topic" questions and responses are now subject to deletion and/or warnings.
The forum is literally falling apart when almost all the threads stray from the topic.
I won't let that happen. :a:
If you guys want to chat about movies and what-not, do it in the Basement forum.
Not here.
Old Jun 17, 2005 | 12:28 PM
JoshJ's Avatar
JoshJ
bang bang.
Not here.
Thank you TheOtherDave.
Now, one last question regarding the clusters. do all 94-01 gsr cluster look exactly the same? will they all hook up the same when i repin my civic harness?
Old Jun 17, 2005 | 05:05 PM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
Not sure about looks, but all 94+ clusters hook up the same. I had a problem with my gas gauge and speedo gauge, so i bought a gauge off a 94 LS get, and just swapped the front peice and they hook up the exact same way.
Old Jun 17, 2005 | 08:14 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
94+ clusters look the same as far as shapes...as far as where they redline it depends what model you get the cluster from...not sure if it'll work on yoru civic harness though
Old Jun 19, 2005 | 09:44 AM
JoshJ's Avatar
JoshJ
bang bang.
im looking at this one:
is this a gsr? im guess the thing that looks different is the actual red lines for the redline. in shmoo's it looks like the red line is solid, however in the one above it is small red lines. maybe i just cant see correctly.
Old Jun 21, 2005 | 12:48 PM
JoshJ's Avatar
JoshJ
bang bang.
Alright, he said its a 98 GSR cluster. does this look right?
does this look the same as a 2000 or 2001 gsr cluster?
also, all i have to do is repin my civic harness to make this fit right?
Old Jun 21, 2005 | 06:39 PM
JoshJ's Avatar
JoshJ
bang bang.
bump, sorry but i need to know asap!!!!
Old Jun 21, 2005 | 07:45 PM
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
looks right to me.
and once again soory dave
Old Jun 21, 2005 | 08:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I really don't know what cluster that is. The little key light at the bottom near the maintenence required looks like something I have never seen.
It could be a GSR cluster, or it could be some other model that redlines at 8k. Either way it should work since you are getting a GSR that redlines at 8k.
Old Jun 21, 2005 | 10:36 PM
Hondaman's Avatar
Hondaman
Black Pearl
That cluster is the same one I have in my 2001 GSR. The little key light is for theft deterant. The ignition key has a micro-chip in it and if the correct key is not inserted, it shuts off the fuel pump.
