H&R Sport springs and what shocks ?
Old May 26, 2005 | 04:31 PM
Brar's Avatar
Brar
does the brand for the camber matter? wats the difference between them all? materials used and reliability? do they make onmipower cambers for g2 tegs? i dont c any...... if they dont wats a good front camber for the g2? and wat kind of adjustment should i look for if i drop with the h&r racing springs on gr2s...
Old May 26, 2005 | 05:14 PM
dubcac's Avatar
dubcac
I
The skunk2 or omnipower camber kits are what I recommend. Much more precise and easier adjustment, and it replaces the upper control arm.
Old May 26, 2005 | 05:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I agree. I have the Skunk2 in front but if I had to do it again, I would get the omnipower. They are cheaper and I have heard better things about them than the Skunk2. Skunk2 camber kits are still way better than the Ingalls front camber shims, though.
Old May 26, 2005 | 06:18 PM
dubcac's Avatar
dubcac
I
The omnipower is essentially a skunk2 copy from what I've seen/heard...just cheaper.
Old May 26, 2005 | 06:56 PM
Brar's Avatar
Brar
:-/ no skunk2 cambers for g2 either wats a good one for the g2? and wat kind of degree correction am i looking for?
Old May 26, 2005 | 10:16 PM
Provocateur
On permanent hiatus
If they don't make omnipowers (which I doubt they do) for the 2nd gen, you may be stuck with the ingalls kit. It isn't that bad but it definitely isn't quite as precise or easily adjustable as a new upper control arm like the omnipower and skunk2 kits.
Old May 27, 2005 | 09:43 AM
Brar's Avatar
Brar
mmk ty, wat kind of degree adjustment should i look into? and should i get rubber or poly?
Old May 30, 2005 | 06:01 AM
BONE's Avatar
BONE
Im have the prokit and yellows and have the omni power front kit and didnt need the rear even though the kit came with the rear washers and bolts. I heard that the Skunk 2 kit would tear but if you look at their ads they advertise the newly designed version so I think the problems has been fixed. Thats why I went with the Omni power one in the first place. Either one would be an excellent choice.
