High-flow cat?
I don't believe car-sound has a bolt on cat for a 00' LS. You might have to get someone to custom weld the flanges.
IPSracing has a good customer track record for welding up carsound converters.
Originally Posted by aboobybobpleez
I have obd2 and im throwing code 65 so if i get a obd1 ecu and harness will my cel go away and i can take my cat off?
What's the better buy here though, an ECU plus a conversion harness or a new secondary O2 sensor?
Has anyone had problems passing emissions on a OBDII vehicle equipped with a OBDI ECU?
Originally Posted by carta79
Running a straight pipe instead of a high flow cat yields a very minor gain. It would give a small power gain but who knows what it does to your torque numbers.
Originally Posted by SP00NFed
How do you know this gives you a minor gain and loss in torque... Do you have evidence to back your statement up, cause im very interested in seeing what the test pipe actually does as far as numbers go. As far as your statement that it pollutes the enviorment i agree 100% with you.
Aftermarket High Flow Cats Versus Testpipes On A Daily Driver:
Comparing a 2.5 in. testpipe (RED) to a 2.5 in. Carsound cat (BLUE) in the same ITR ( 1.8L B18C5 ) with a CAI, Toda B cams, an SMSP 4-2-1 long hybrid header (2.5 in. OD collector), and SMSP 2.5 in. OD exhaust, Apex Power FC fuel tuning:
I never specifically stated that you would lose torque in my previous post. The numbers look to be 188.5 with the Carsound and 190 with the straight pipe, but the graph looks blurry and my vision is pretty bad.
How's that for "evidence" ?
that is very good evidence...but you are comparing a highflow cat to a test pipe...now can you tell me how much more hp gain the test pipe or the high flow is compared to the stock cat?
Jesus, Mary and Joseph :doh:
