Removing Pwr Steering = HP? - Lets settle this
Originally Posted by Qbacca
You don't want to do that, the ratio on the manual rack sucks.
I kinda figured the manual rack would be like 7 trillion turns lock-to-lock..
h:
If you were to remove the ac and ps belt and all the pumps then replace it with a lightweight underdrive pulley there would be a diference to make it worth the time. just removing them to increase HP, give me a break. not enough to warrant the work.
Well I will add my two cents.
I pulled my power steering off and I loved it. To me it felt better and I DEFINITELY felt a difference. MY butt dyno told me that it revved slightly freer. I also remember someone saying they saw a dyno chart somewhere for a type r. One with ps and one without. The one without they gained 10hp and 7ft/lbs of torque. That was the only change.
10hp and 7ft/lbs of torque, dang that would be awesome, unfortunately I find it highly unlikely, unless they somehow had the P/S drawing a full load during the first dyno test, then stripped it and dyno'd it again. But as we discussed, that's not normal driving conditions, except when accelerating around a corner. Thanks for your 2 cents.
I can't verify that I just remember reading that somewhere. But I definitely felt a difference. Besides I liked the feel better. I think they are over boosted stock, there is a better road feel without PS.
I have been running without my power steering and A/C for over a year now and from my perspective I preffer driving without them both. The only time I wish I had A/C is in the rain when the windows fog, but...ehhh.
The reasons I did it was to clear up space in the engine bay because I think it looks a lot less cluttered and cleaner, drop some weight (those components are really heavy especially the brakets), and make some cheap HP & TQ gains. I still have not gone to the dyno because I am lazy but the biggest thing I noticed was the engine reving a lot quicker. There did seem to be a bit of a boost in power but that is on the butt dyno and nothing scientific. I also added the CTR N1 crank pulley to shave a few more lbs. and also removed my cruise control. All this I sold on eBay and bought other mods with the money.
Basically it really is a prefference thing for people. I never used the A/C and preffer to drive without P/S...for me to take these systems off my car was a no brainer. For other people they may like to have them. If you do remove the P/S definately get a breather kit to keep the rack lubed and prevent dirt from getting in there.
Good stuff Tom, good points. I live in CA and use A/C year round, but I often flip it off when I need an acceleration boost, my butt dyno tells me A/C on vs. A/C off equals 5hp. Sounds like you've got a good setup and I can see where your mods together would make significant difference.
Originally Posted by shabacash
So many complaints about parallel parking.
People who can parallel park well(quickly), you are safe to take your power steering off.
Talk to me once you've parallel parked on Divisadero, pointed downhill at 12 degrees, with a MUNI bus bearing down on you at 35 mph...in a spot that's about 3 feet longer than your car.
You have less than 20 seconds to get the job done.
