No Spark and No Fuel
Old May 19, 2005 | 08:49 AM
keg's Avatar
keg
Originally Posted by Epoch
Failing ignition coils in distributors, yes... but the dists themselves seem pretty rock solid. But, if those were failing, you would get no spark...
When I tested the coil I got slightly off numbers for the resistance than spec but thought it was just my multi-meter. What would a failing coil do?
Old May 19, 2005 | 09:26 AM
Schwa's Avatar
Schwa
Schiggity
Prevent you from sparking. The coil is quite common, mine's already been changed once and I've had my car like 6 months
Old May 19, 2005 | 11:34 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
If they're even just a little out of spec with an ambient temperature of 70 degrees F, your coil will not allow your car to spark
Old May 24, 2005 | 10:47 AM
keg's Avatar
keg
It was the coil, thank you all for the help.
Old May 24, 2005 | 12:19 PM
Epoch's Avatar
Epoch
Sweetness. A fairly painless job, pending your rotor cap screw isn't rusted into the spindle
