Best oil for integras?
Old May 19, 2005 | 04:11 PM
  #31
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
They're the same company that makes the filters that Spoon Sports uses... I'd say they're good
Old May 19, 2005 | 04:46 PM
  #32
tto's Avatar
tto
I use Mobil 1 or Royal Purple 10w-30 in my LS/VTEC. Convental oils boil at 250 Degrees and coke very quickly. Synthetic allows for better performance and does not allow for crank drag like convential oil.
Old May 24, 2005 | 11:56 PM
  #33
stoner02420's Avatar
stoner02420
Comples Performance
well i just did an oild change dont know what oil it had in it but i used mobile 1 10w30 and a oem filter from honda....but now i have a tap any reason?.......some one told me since my car has 136,000 miles i should use like 20w50 is dis tru?
Old May 25, 2005 | 04:29 AM
  #34
SP00NFed's Avatar
SP00NFed
FuK JDM
what about fram's higher line of oil filters...you think they are a little better than the cheap 3$ filters
Old May 25, 2005 | 08:29 AM
  #35
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
I don't trust FRAM at all. So I have a very hard time believing they are capable of building a "higher line" of oil filters.
I won't give an up-or-down vote until I see detailed pics of the filter internals and a lab report of how well the filter membrane performs.
But my initial impression is that talk is cheap.
Our motors deserve the very best in fluids and filters.
Old May 25, 2005 | 10:27 AM
  #36
DVPGSR's Avatar
DVPGSR
I need sleep...
Mobil 1 5w-30 from the day I bought it.
Old May 28, 2005 | 05:05 AM
  #37
csprague's Avatar
csprague
Warthog Pointyhead
Originally Posted by TheOtherDave™
I'd steer clear of that engine restore. :eh: I used it as a get-by on my GTi, just before I was going to major engine work. When I tore down the old motor, I was shocked at the sludgy crap around the bottom piston rings. No wonder they claim an increase in compression...h:
Since I'm in a more temperate climate, I run Castrol GTX 5w30 and Hastings #403 filters.
[Don't run any of that FRAM crap, you hear? ]
Since super-cold starting temps aren't an issue, I use a lighter weight oil.
Given your northeastly winters, the 10/40 is a good compromise.
Higher weight oil for lower temperatures?? Explain your reasoning??
Back to the topic, I run Mobil 1 5W30 for a multitude of reasons, but mainly so I can double my normal oil change interval (because changing the oil is a pain)
Old May 28, 2005 | 05:06 AM
  #38
csprague's Avatar
csprague
Warthog Pointyhead
if your valvetrain is noisy than you might want to adjust the valve lash.
Old May 28, 2005 | 05:34 AM
  #39
DVPGSR's Avatar
DVPGSR
I need sleep...
A higher weight oil will be thicker than a lower weight oil. If you live in a southern climate where the weather is hotter having a higher weight oil in your car will not break down as much as a lighter weight oil. Conversely, in a northern, colder climate a lower weight oil is not as thick and will be better for an engine on a cold, winter day. It all breaks down to the viscosity level of the oil.
Old May 28, 2005 | 07:25 AM
  #40
csprague's Avatar
csprague
Warthog Pointyhead
Thanks, I know all about the viscosity of oil etc. My question to the original poster is why he advocates the opposite...
